JS110 python joulescope questions
I am using a python script with the joulescope package to automate Joulescope validation testing. This works well with the JS220 and I’m adapting a separate script for JS110 but I am encountering “pkt_index skip” messages on each read. These don’t really break anything (I still get the expected amount of data, the data looks good, and I think this is expected behavior at read startup for JS110), but the text does visually disrupt the logging for intermediate results. I generally see two skip messages per read. For clarity, here’s an example of the skip messages:
pkt_index skip: expected 0, received 16229
pkt_index skip: expected 16252, received 0
Is there a way to suppress / disable the logging for the “pkt_index skip“ messages? Ideally it would be suppressing just that message so I can see others, but adjusting the log level could be an option too.
The other question I have on the joulescope package is what is the right way to find the parameters for a device? Assuming something like
import joulescope
JS = joulescope.scan_require_one(config=‘auto’)
then using JS.parameters() returns a list of objects that aren’t very clear: [<joulescope.parameter.Parameter object at 0x000002B6CF4D0AF0>, <joulescope.parameter.Parameter object at 0x000002B6CF3977F0>,
List comprehension printing ([print(x) for x in JS.parameters()]) does show parameter names, but I suspect there’s an easier way.
pkt_skip
The JS110 streaming often does not start cleanly. You get a small burst of samples, a gap, and then a continuous stream of samples. The pkt_index skip indicates this.
The pkt_index skip messages come from js110_usb.c in joulescope_driver. You have a few options:
  1. Change the log level to error. I think that the following code should work:
from joulescope import DriverWrapper, scan_require_one
DriverWrapper().driver.log_level = 'ERROR'
  1. Fork joulescope_driver and delete this line.
Parameters
The easiest way is probably parameters_v1.py.
For all of the JS220 topics available to publish, try this:
python -m pyjoulescope_driver info -v "*"
Thank you!
Adjusting the log level with DriverWrapper is a good solution.
To minimize the chances of suppressing important information I saved, modified, and restored the log level around the read functions with
log_level = joulescope.v1.DriverWrapper().driver.log_level
joulescope.v1.DriverWrapper().driver.log_level = ‘ERROR’ # Suppress the pkt_index skip message which occurs on JS110 reads.
js_reading = JS.read(1)
joulescope.v1.DriverWrapper().driver.log_level = log_level # Restore the logging level
This was also to avoid having to import separately from joulescope.v1 for DriverWrapper and from joulescope for scan_require_one and read.
The Parameters link had good info and I found
joulescope.v1.js110.PARAMETERS_DICT.keys()
generated a succinct list of the parameter names for the device.
At first I didn’t see any results when running
but after plugging in a Joulescope, it shows the info for that device.
Yes, this is the expected behavior with the JS220. The JS220 firmware actually defines the topics, not the host side, so the host needs to have a JS220 to query.
