Hi @hthalljr! Here is a script that can read a JLS file and extract points to a CSV file:
#!/usr/bin/env python3
# Copyright 2024 Jetperch LLC
# http://www.apache.org/licenses/LICENSE-2.0
"""Read a JLS file, compute points, and export a CSV file."""
from pyjls import Reader
from pyjoulescope_driver import time64
import argparse
from datetime import datetime
import numpy as np
import sys
def _ratio_validate(s):
f = float(s)
if f < 0 or f > 1.0:
raise ValueError(f'Invalid ratio {s}')
return f
def parser_config(p):
p.add_argument('--verbose', '-v',
action='store_true',
help='Display verbose information.')
p.add_argument('--columns',
default='voltage,current',
help="""The JLS signals to export to CSV. Defaults to "voltage,current".
Signals may be specified in any of the following formats:
signal_name, signal_id, source_id.signal_name, source_name.signal_name""")
p.add_argument('--offset',
help='The starting offset in ISO 8601 format such as YYYYMMDDThhssmm.ffffffZ')
p.add_argument('--duration',
type=time64.duration_to_seconds,
help='The capture duration, which defaults to units of float seconds. '
+ 'Add a suffix for other units: s=seconds, m=minutes, h=hours, d=days. '
+ 'If not specified, use the entire file.')
p.add_argument('--ratio',
type=_ratio_validate,
default=1.0,
help='The ratio of used samples for each point from 0.0 to 1.0. '
+ '1.0 uses all samples in the point range. '
+ '0.0 uses one sample.')
p.add_argument('--no-header',
help='Omit the CSV header when specified.')
p.add_argument('--count',
type=int,
default=100,
help='The number of points to compute over the duration')
p.add_argument('input',
help='The input filename path.')
p.add_argument('output',
help='The output filename path.')
return p
def on_error(msg):
sys.stderr.write(f'ERROR: {msg}\n')
sys.stderr.flush()
return 1
def on_cmd(args):
r = Reader(args.input)
# determine CSV columns
sources = dict([(source.source_id, source.name) for source in r.sources.values()])
signals = {}
columns = []
for signal in r.signals.values():
source_name = sources[signal.source_id]
signals[(str(signal.source_id), signal.name)] = signal
signals[(source_name, signal.name)] = signal
signals[(str(signal.signal_id), )] = signal
signals[(signal.name, )] = signal
for column in args.columns.split(','):
parts = column.split('.')
signal = signals[tuple(parts)]
if len(sources) > 2:
column_name = f'{sources[signal.source_id]}.{signal.name}'
else:
column_name = signal.name
column_element = {
'name': column_name,
'signal': signal,
't_start': r.sample_id_to_timestamp(signal.signal_id, 0),
't_end': r.sample_id_to_timestamp(signal.signal_id, signal.length - 1),
columns.append(column_element)
if args.verbose:
print('Columns to export:')
for column in columns:
t_start = time64.as_datetime(column['t_start']).isoformat()
t_end = time64.as_datetime(column['t_end']).isoformat()
print(f' {column["name"]}: {t_start} to {t_end}')
# Determine offset and duration
# Use timestamp to align the points across signals since
# JLS signals are independent, may be at different sample rates,
# and are not guaranteed to be sample aligned.
t64_start = max([e['t_start'] for e in columns])
t64_end = min([e['t_end'] for e in columns])
if args.offset:
t64_offset = time64.as_time64(datetime.fromisoformat(args.offset))
if t64_start <= t64_offset < t64_end:
t64_start = t64_offset
else:
t1 = time64.as_datetime(t64_offset).isoformat()
t2 = time64.as_datetime(t64_start).isoformat()
t3 = time64.as_datetime(t64_end).isoformat()
return on_error(f'offset {t1} out of range: [{t2}, {t3}]')
t64_duration = t64_end - t64_start
if args.duration is not None:
args_duration = int(time64.SECOND * args.duration)
if args_duration > t64_duration:
t1 = time64.duration_to_seconds(args_duration)
t2 = time64.duration_to_seconds(t64_duration)
return on_error(f'Duration exceeded: {t1} > {t2}\n')
t64_duration = args_duration
if args.verbose:
t_start = time64.as_datetime(t64_start).isoformat()
t_end = time64.as_datetime(t64_start + t64_duration).isoformat()
print(f'Export {args.count} points over {t_start} to {t_end}')
# compute each point
data = np.empty((args.count, len(columns)))
ratio = args.ratio
for col_idx, column in enumerate(columns):
signal = column['signal']
signal_id = signal.signal_id
s_start = r.timestamp_to_sample_id(signal_id, t64_start)
s_end = r.timestamp_to_sample_id(signal_id, t64_start + t64_duration)
if (s_end - s_start) < args.count:
print(f'{column["name"]}: less than one sample per point')
sample_ids = np.floor(np.linspace(s_start, s_end, args.count + 1)) # need end since using as range
for row_idx, s in enumerate(sample_ids[1:]):
s_count = max(1, int((s - s_start) * ratio)) # force at least one sample
data[row_idx, col_idx] = r.fsr_statistics(signal_id, s_start, s_count, 1)[0][0]
s_start = int(s)
# Save to CSV file
if args.no_header:
np.savetxt(args.output, data)
else:
header = ','.join([column['name'] for column in columns])
np.savetxt(args.output, data, header=header)
return 0
def run():
parser = argparse.ArgumentParser(parser_config.__doc__)
parser = parser_config(parser)
args = parser.parse_args()
return on_cmd(args)
if __name__ == '__main__':
sys.exit(run())
I also added this to pyjoulescope_examples.
To use this script, you need to install python. Assuming python is then on your path, you can install the dependencies using:
python -m pip install pyjls pyjoulescope_driver
If you save the script as jls_export_points.py, you can then run the script like this:
python jls_export_points.py {in.jls} {out.csv}
Replace {in.jls} and {out.csv} with the full paths to your input and output files. For help on all the arguments, type:
python jls_export_points.py --help
We could also add a current-voltage analysis range tool. It would show up as another range tool when you right-click on a dual marker and seelct Analysis, like this:
Do you do any math before plotting current vs voltage? If you perform math to manipulate the current & voltage, is this something that you are able to share publically?
