Loading a broken recording does not show anything
Hi all,
we have a interrupted recording (38GB) from a Joulescope JS110 and Joulscope UI 1.0.48.
When I try to open that one with Joulescope UI 1.1.10 I get now error message and no signals indicated. I get the attached LOG file.
joulescope_20240917_083615_21184.log (52.6 KB)
If I open the recording with the file viewer I get the information that it should contain samples:
0) global_annotation_source : 1.0.0
  1. JS110-001677 : {“hw”: 1}
    current : 4796334080 samples @ 20000 Hz
    voltage : 4796334080 samples @ 20000 Hz
    current_range : 4795924480 samples @ 20000 Hz
    The file viewer does not display the signals eigther.
How can I fix and upgrade the recording file, so I see the signals within the JouleScope UI 1.1.10?
best regards
ps_water
Hi all,
I solved the issue.
The use of the pyjls tool copy did work.
python -m pyjls copy <src> <dst>
best regards
ps_water
