Logging data while running other code
Hello, I would like to start logging data and then run some other python code, then stop logging data. So I would either want to start logging for say 100 second and then run my other code or start logging run the other code then stop logging.
The issue I am having is that when I start logging, the code either runs for x amount of seconds before I can run the other code or I have to use ctrl + c before the other code runs. Would you mind showing me an example on how to get around this problem?
Hi @Xylophone and welcome to the Joulescope forum!
I have a few questions:
  1. Can you clarify what you mean by “logging data”? Joulescopes can provide two types of data:
    a. Streaming sample data which is normally recorded to JLS files
    b. Streaming statistics data, which can be recorded to CSV files.
  2. Are you using a Joulescope JS110 or JS220?
  3. Do you care how you access the Joulescope devices through Python? You can use the pyjoulescope package or directly use the newer underlying pyjoulescope_driver.
  1. Right now I am using the downsample_logging.py script, so it would be statistics data. I am mainly measuring the time and current down to nA range.
  2. I am using JS220
  3. I do not think I care. Are there any differences? Right now I am using the pyjoulescope package.
How about something like this?
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# Copyright 2019-2024 Jetperch LLC
"""Display statistics from the first connected Joulescope."""
from joulescope import scan
import time
def statistics_callback(stats):
    """The function called for each statistics.
    :param stats: The statistics data structure.
    t = stats['time']['range']['value'][0]
    i = stats['signals']['current']['µ']
    v = stats['signals']['voltage']['µ']
    p = stats['signals']['power']['µ']
    c = stats['accumulators']['charge']
    e = stats['accumulators']['energy']
    fmts = ['{x:.9f}', '{x:.3f}', '{x:.9f}', '{x:.9f}', '{x:.9f}']
    values = []
    for k, fmt in zip([i, v, p, c, e], fmts):
        value = fmt.format(x=k['value'])
        value = f'{value} {k["units"]}'
        values.append(value)
    ', '.join(values)
    print(f"{t:.1f}: " + ', '.join(values))
def run():
    devices = scan(config='off')
    if not len(devices):
        print('No Joulescope device found')
        return 1
    device = devices[0]
    device.statistics_callback_register(statistics_callback)
    device.open()
    try:
        device.parameter_set('i_range', 'auto')
        device.parameter_set('v_range', '15V')
        time.sleep(10)   # replace with your code
    finally:
        device.close()
if __name__ == '__main__':
    run()
I will take a look at the body of the statistics_callback function.
I managed to make it work by using multiple processes like so:
import threading
import subprocess
def run_script(script_args):
    subprocess.run(["python"] + script_args.split())
if __name__ == "__main__":
    script1_args = "downsample_logging.py --time 100 --frequency 100"
    script2_args = "current_leakage_test.py"
    script1_thread = threading.Thread(target=run_script, args=(script1_args,))
    script2_thread = threading.Thread(target=run_script, args=(script2_args,))
    script1_thread.start()
    script2_thread.start()
    script1_thread.join()
    script2_thread.join()
Hi @Xylophone - Yes, using python to run two processes can definitely work.
If you want a single, integrated python script, the example I provided is a good start. You can modify the statistics_callback function to do whatever you want with the statistics. If you also want to maintain state, like an open file handle, you could convert this to a class with a __call__ method.
Does this give you what you want?
