Different results from fsr() and fsr_statistics() for gpi signal
I have recently been using pyjls library to read Joulescope’s GPI signals from a JLS file recorded with Joulescope UI.
Since reading the whole measurement results using fsr() method is insufficient for further post-processing, I have started using fsr_statistics() method instead. It works great with current signal, but I have noticed stranger behavior when comparing these two methods for GPI signals…
Below is my Python script, which I use to visualize data from a JLS file with matplotlib library:
import numpy as np
from pyjls import Reader
import matplotlib.pyplot as plt
FILE_PATH = r"########.jls"
FIXED_VAL = 1000
with Reader(FILE_PATH) as r:
    current_signal = r.signal_lookup('current')
    reading_fsrstats_current = r.fsr_statistics(current_signal.signal_id, 0, FIXED_VAL,
                                                int(current_signal.length / FIXED_VAL))[:, 0]
    reading_fsr_current = r.fsr(current_signal.signal_id, 0, current_signal.length)
    gpi0_signal = r.signal_lookup('gpi[0]')
    reading_fsrstats_gpi0 = r.fsr_statistics(gpi0_signal.signal_id, 0, FIXED_VAL,
                                                int(gpi0_signal.length / FIXED_VAL))[:, 0]
    reading_fsr_gpi0 = r.fsr(gpi0_signal.signal_id, 0, gpi0_signal.length)
# Plot current signal
reading_fsrstats_current_tvec = np.arange(0, reading_fsrstats_current.size)
reading_fsr_current_tvec = np.arange(0, reading_fsr_current.size)
plt.figure()
plt.subplot(2,1,1)
plt.plot(reading_fsrstats_current_tvec, reading_fsrstats_current)
plt.title('Current measurement (fsr_statistics): mean for every %d samples' % FIXED_VAL)
plt.xlabel('Sample')
plt.ylabel('Amplitude [~]')
plt.grid()
plt.subplot(2,1,2)
plt.plot(reading_fsr_current_tvec, reading_fsr_current)
plt.title('Current measurement (fsr)')
plt.grid()
# Plot GPIO[0] signal
reading_fsrstats_gpi0_tvec = np.arange(0, reading_fsrstats_gpi0.size)
reading_fsr_gpi0_tvec = np.arange(0, reading_fsr_gpi0.size)
plt.figure()
plt.subplot(2,1,1)
plt.plot(reading_fsrstats_gpi0_tvec, reading_fsrstats_gpi0)
plt.title('GPI[0] measurement (fsr_statistics): mean for every %d samples' % FIXED_VAL)
plt.grid()
plt.subplot(2,1,2)
plt.plot(reading_fsr_gpi0_tvec, reading_fsr_gpi0)
plt.title('GPI[0] measurement (fsr)')
plt.grid()
plt.show()
Here are the two plots I obtained:
The part I do not understand is:
Why are the subplots of the GPI[0] signal not aligned with each other?
Why is sample 15,000 from the upper plot near the 4th rising edge, while sample 1.5e6 is in the middle of the 3rd full high state?
Is this some kind of bug, or am I missing something?
Thanks in advance for your support!
My environment:
  • OS: Win-11
  • Joulescope: JS110
  • Joulescope App:
    • UI: 1.2.5
    • driver: 1.7.2
    • JLS: 0.11.1
    • Python 3.11.9
    • Platform: Windows-10-10.0.22631-SP0
  • Python: 3.13.1
  • Python Packages:
    • pyjls: 0.11.1
    • matplotlib 3.10.0
Hi @jakkok - Thanks for the python code to demonstrate the issue.
The JLS file format is very powerful and flexible, but that also means that there are a few challenges in processing the data. You script does not account for:
  1. Sample rate: The sample rate for current is 1,000,000, but the sample rate for GPI0 is 2,000,000. The easiest solution is to display the x-axis as time (seconds) rather than samples.
  2. data packing: The GPI0 digital data is packed into a u8 and needs to be unpacked. For what its worth, this is documented.
  3. signal alignment: Data is not necessarily sample aligned, even for the same instrument. It is definitely not aligned if you record from multiple instruments. See extract.py for the general case.
Here is the updated code that works:
import numpy as np
from pyjls import Reader, time64
FILE_PATH = r"20250212_162935.jls"
FIXED_VAL = 1000
    print(f'current = {current_signal}')
    print(f'gpi0 = {gpi0_signal}')
    signals = [current_signal, gpi0_signal]
    t_start = max([r.sample_id_to_timestamp(signal.signal_id, 0) for signal in signals])
    t_stop = min([r.sample_id_to_timestamp(signal.signal_id, signal.length - 1) for signal in signals])
    t_duration = (t_stop - t_start) / time64.SCALE
    print(f'duration = {t_duration}')
    x_start = r.timestamp_to_sample_id(current_signal.signal_id, t_start)
    x_stop = r.timestamp_to_sample_id(current_signal.signal_id, t_stop)
    reading_fsrstats_current = r.fsr_statistics(current_signal.signal_id, x_start, FIXED_VAL,
                                                int((x_stop - x_start) / FIXED_VAL))[:, 0]
    reading_fsrstats_current_tvec = np.arange(0, reading_fsrstats_current.size) * (t_duration / reading_fsrstats_current.size)
    reading_fsr_current = r.fsr(current_signal.signal_id, x_start, (x_stop - x_start))
    reading_fsr_current_tvec = np.arange(0, reading_fsr_current.size) * (t_duration / reading_fsr_current.size)
    x_mask = 0xffff_ffff_ffff_fff8
    x_start = r.timestamp_to_sample_id(gpi0_signal.signal_id, t_start) & x_mask
    x_stop = (r.timestamp_to_sample_id(gpi0_signal.signal_id, t_stop) + 7) & x_mask
    reading_fsrstats_gpi0 = r.fsr_statistics(gpi0_signal.signal_id, x_start, FIXED_VAL,
    reading_fsrstats_gpi0_tvec = np.arange(0, reading_fsrstats_gpi0.size) * (t_duration / reading_fsrstats_gpi0.size)
    reading_fsr_gpi0_u8 = r.fsr(gpi0_signal.signal_id, x_start, (x_stop - x_start))
    reading_fsr_gpi0 = np.unpackbits(reading_fsr_gpi0_u8, bitorder='little')
    reading_fsr_gpi0_tvec = np.arange(0, reading_fsr_gpi0.size) * (t_duration / reading_fsr_gpi0.size)
plt.figure()
plt.subplot(2,1,1)
plt.xlabel('Time (s)')
plt.grid()
plt.subplot(2,1,2)
plt.grid()
plt.figure()
plt.subplot(2,1,1)
plt.grid()
plt.subplot(2,1,2)
plt.grid()
plt.show()
Here are the resulting plots:
Does this make sense and answer your questions?
