i am trying to run joulescope UI on my machine running 22.04.5 LTS (Jammy Jellyfish).
The issue started first on joulescope launcher version 1.2.2 where i get the following error message:
WARNING:2025-01-14 15:23:15,307:backend.c:380:jsdrv:zero length bulk in transfer
qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x0
I get the pop-up telling me a new version is available, when i press “later” the window closes and nothing more happens. There is a process running, but no window shows up.
When updating to 1.2.5 (latest at this time) i get this error when trying to run:
[PYI-107012:ERROR] Failed to load Python shared library ‘/home/esr/Documents/joulescope/joulescope_1_2_5/_internal/libpython3.11.so.1.0’: dlopen: /lib/x86_64-linux-gnu/libm.so.6: version `GLIBC_2.38’ not found (required by /home/esr/Documents/joulescope/joulescope_1_2_5/_internal/libpython3.11.so.1.0)
