Small feature request - default image save directory
Hi Matt, this is a minor but annoying thing if you’re exporting a number of images: Joulescope always saves to some fixed Joulescope directory; it’d be nice if it would remember where I last saved to.
Hi @JuliaTruchsess and thanks for the feedback. I thought that the UI already did this, but no! It saves to the path in Preferences → General → data_path. All the other saves respect the data_path_type setting which is either the data_path, most recently saved, or most recently used. Saving the image also does not update the most recently used/saved path.
I created issue #136. This will be fixed in the next release.
In the meantime, you can edit Preferences → General → data_path to what you would like.
