But parameter_set() is not implemented (also info() isn’t implemented)
def parameter_set(self, name, value):
"""Set a parameter value.
:param name: The parameter name
:param value: The new parameter value
:raise KeyError: if name not found.
:raise ValueError: if value is not allowed
raise NotImplementedError()
Hi @sallen ! I am assuming you are talking about the joulescope python package. The v1 backend should work the same as the v0 backend. Note that Device in joulescope/device.py is the base class, which raises the NotImplementedError. If you look at DeviceJs110 in joulescope/v1/js110.py you will see the implementation for the JS110. DeviceJs220 in joulescope/v1/js220.py is for the JS220.
Did you try the v1 backend and find something not work? If so, what was the error?
My bad - I’d been running with a wrapper around the base class which was working in a pre 1.0 joulesope driver. I’m also opening the driver multiple times which used to be tolerated and is no longer. I’ll come back once I have these figured out.
The returned info() is much reduced but that’s a minor issue.
