I am using JS220 for IoT product power consumption measurements, and its performance exceeds expectations. In the next step, I plan to code some Python scripts to control JS220.
There is only one question that I would like to ask (I have searched the Q&A but haven’t found the answer; please let me know if this question has been asked before):
I have referred to the Joulescope examples, and I have understood how the current range is set as follows:"
However, JS220 has added the ability to limit the upper and lower limits of the current range used during the “auto” current range as follows. How should I use Python to set it? Thanks
(For example, I would like to set “auto mode within 180 µA - 18 mA”)
Great to hear that the JS220 is working well for you. Congratulations on taking the next step to automate things using Python!
Unfortunately, you are not missing anything. The joulescope package only has full support for the parameters used by both the JS110 and the JS220. The JS220-specific parameters are currently only supported through the lower level pyjoulescope_driver package. Figuring out how to expose the device-specific parameters through the joulescope package is still on our list of things to do.
{edit} We do have a way using the publish method and joulescope package. See next post for details. If you would rather use the pyjoulescope_driver package directly, keep reading.
As of today, the easiest approach is likely to use the pyjoulescope_driver package directly. The joulescope package v1 backend simply wraps the pyjoulescope_driver package as you can see here.
Here are some resources for using the pyjoulescope_driver package:
If not, I am happy to help put together something closer to what you need. What actions are you looking to perform with your JS220 through the Python script?
Note that this only works with the default v1 backend which supports the JS220 and JS110. The publish method does not exist for the legacy v0 backend which only supports the JS110.
Thanks for getting back to me so quickly.
I am interested in the second method using the joulescope package.
I attempted to call the publish method in my code, but it seems that the publish method can not be found.
Additionally, when I tested the detector.py, it looked like something was lost:
