Error with no Stream Buffer
I’m trying the simple example:
import joulescope
import numpy as np
with joulescope.scan_require_one(config='auto') as js:
    data = js.read(contiguous_duration=0.1)
current, voltage = np.mean(data, axis=0, dtype=np.float64)
print(f'{current} A, {voltage} V')
I get the error that’s looking like no StreamBuffer object. I’m sure it used to work
_on_cmd_publish_cbk(u/js220/001846/s/gpi/1/!data)
File “pyjoulescope_driver/binding.pyx”, line 1029, in pyjoulescope_driver.binding._on_cmd_publish_cbk
File “/home/tomh/.local/lib/python3.12/site-packages/joulescope/v1/device.py”, line 461, in _on_stream
if self.stream_buffer.is_duration_max or self.stream_buffer.is_contiguous_duration_max:
AttributeError: ‘NoneType’ object has no attribute ‘is_duration_max’
API command u/js220/001846/@/!close invoked on jsdrv thread with timeout. Forcing timeout=0.
Hi @TomH, and welcome to the Joulescope forum!
Well, this example works for me:
PS C:\project\Joulescope\support\2025\10\20251031> python .\example.py
6.203842349350452e-09 A, 0.08853064665184356 V
What do you see when you run:
python -m pyjoulescope_driver info
Here is what I see:
    SYSTEM INFORMATION
    python               3.13.7 (tags/v3.13.7:bcee1c3, Aug 14 2025, 14:15:11) [MSC v.1944 64 bit (AMD64)]
    python impl          CPython
    platform             Windows-11-10.0.26200-SP0
    processor            Intel64 Family 6 Model 183 Stepping 1, GenuineIntel
    CPU cores            24 physical, 32 total
    CPU frequency        3000 MHz (0 MHz min to 3000 MHz max)
    RAM                  34.8 GB available, 63.7 GB total (54.7%)
    PYTHON PACKAGE INFORMATION
    jls                  0.15.0
    joulescope           1.3.1
    numpy                2.3.3
    pyjoulescope_driver  1.10.0
    JOULESCOPE INFORMATION
    u/js220/001062: hw=1.0.0, fw=1.3.0, fpga=1.3.3
Note that according to numpy NEP 29, which we follow, you should be running Python 3.11 or newer.
Output from python -m pyjoulescope_driver info:
SYSTEM INFORMATION
python               3.12.3 (main, Aug 14 2025, 17:47:21) [GCC 13.3.0]
python impl          CPython
platform             Linux-6.8.0-40-generic-x86_64-with-glibc2.39
processor            x86_64
CPU cores            2 physical, 4 total
CPU frequency        3600 MHz (400 MHz min to 3900 MHz max)
RAM                  3.8 GB available, 7.6 GB total (49.1%)
jls                  0.15.0
joulescope           1.3.1
numpy                1.26.4
u/js220/001846: hw=1.0.0, fw=1.3.0, fpga=1.3.3
Ok the example script as given works fine. However if I put a time.sleep(10) after the print() I get the following:
This switches off the switch in the Joulescope. Which is what I’m seeing in my test script.
What I want is to open a connection to the Joulescope and have it keep the internal switch closed while I run a bunch of tests, some of which use the Joulescope.
I think that the issues is that the context manager js automatically closes the device when leaving with. You need to include all of your Joulescope operations inside the context manager. Alternatively, you want to use the open and close methods.
Does this make sense and solve the issue?
Yes thankyou all solved. I’d forgotten what with… actually does!
And Joulescope probably saved my board. I was on the wrong testpoint and it would have drawn too much current and probably cooked the board, but Joulescope just opened the output switch. Thanks Joulescope.
