Joulescope UI - not smooth with regular pause
Hi, we are using the JS220. Its a great tool, so well done!
However I am struggling to get a smooth output from it. Using the Joulescope software (or running the code from Github), Waveform that comes in pauses about every second. I.e. it is not smooth. I have gone through all setting, memory, opengl, sample rates etc but nothing seems to effects the regular pause…
I don’t recall seeing this on my previous computers running Win10
Any pointers?
I have a fairly new I7 machine with 32Gb RAM running Windows 11…
I’ve updated graphics drivers. Done a clean restart.
Hi @KK123 - The Waveform widget should be smooth any ony modern Windows computer with a graphics card. Older integrated Intel graphics is a known issue, but newer integrated Intel graphics works great.
Let’s see if we can figure out the issue:
  1. Is this machine a laptop? If it is a laptop, plug it into the power adapter. Also inspect the power settings.
  2. Ensure that your Joulescope is connected directly to a USB port on your host computer. Do not use any hubs, docks or adapters.
  3. If you have any other USB devices connected to the same USB root hub, disconnect them for this test. We want to make sure some other USB device communication is not the cause.
  4. Take a look at Windows power settings
  5. Start the Joulescope UI, select FileClear config and exit. This reverts the UI to default settings.
  6. Start the Joulescope UI, select ViewOscilloscope.
  7. Does the Waveform widget animate smoothly? If it runs smoothly, great! If not, please select HelpReport Issue. In the issue report. please provide the URL for this forum post. This report will give us more information that may be useful.
What do you find?
Hi @mliberty thanks for your reply.
I have tried all the above… However I have just managed to get my antivirus turned off and that seems to be the culprit. We use Sophos Endpoint and the Real Time File scanning seems to be causing the continuous pause. It is great I’ve isolated the cause, however I am not sure how to get around it. IT policy will required scanning to continue… I guess I could try exclude Joulescope from the scanning…
However I am not recording anything to file as far as I know? What file read/write will be happening when running the joulescope?
The Joulescope UI does write a log to disk, but it should be relatively small. You can select HelpView logs… in the UI to open the log path in Windows File Explorer.
The UI also renders themes and icons to disk, but only when you switch views or add widgets.
That’s all. It does buffer all the incoming data to RAM, about 15 MB/s. If Sophos is trying to scan RAM, that could be a problem.
For what its worth, we do run the joulescope.exe for each Joulescope UI release through VirusTotal. Here are the results for 1.3.4 (latest).
Hi @KK123 - I just had another person report this same behavior with Sophos Endpoint. Did you ever figure out how to work around this problem?
Hi @mliberty, in the end I had to disable file scanning to make it work at full tilt.
Suggesting that Sophos is causing a slow down on the write to disk. Next step would be for me to get the relevant folders added as exclusions for the file scanning part of Sophos I think. But I never took it to that point. I finished my profiling work by just turning it off for a brief time…
When I need to do the next round, I’ll look at a more permanent fix…
I am surprised that the cause was disk scanning rather than memory scanning, especially when not recording to JLS. Another thing to try is to disable logging using the --file_log_level OFF command line option. You can start the Joulescope UI from a command prompt like this:
"C:\Program Files\Joulescope\joulescope.exe" --file_log_level OFF
With PowerShell, you need an extra leading “.”, like this:
. "C:\Program Files\Joulescope\joulescope.exe" --file_log_level OFF
If you try this and it solves the issue, please post with your results.
I’m very interested in this topic because I think I have the same performance issue.
Our company changed its security software and switched to Sophos. I also upgraded to version 1.4.1. Since then, I’ve been experiencing the slowdowns you described.
I was able to run the test you mentioned (–file_log_level OFF), but it didn’t improve performance.
So, I’d appreciate any new solutions you might have.
Best regards.
yoann
Hi @Yoann and welcome to the Joulescope forum!
We don’t have any additional recommendations at this time. Have you been able to temporarily disable Sophos Endpoint to confirm that it is the issue? Can you add exclusions for the Joulescope UI?
Hello Matt,
Many thanks for you answer.
I’ll ask my IT department, but I’m afraid they won’t want to. Especially since they’re remote.
I’ll ask them and keep you posted.
Best regards.
Yoann
PS : For your information, I am Yoann (last name: THOMAS) from the Hager company in France. The department I worked for has been sold. We are now a fully independent company (7s).
Hi @Yoann - congrats on the transition, and good to hear you continue to use your Joulescopes!
The original problem with Sophos Endpoint was the Joulescope log output. Sophos was very aggressively monitoring the log, so much so that it caused significant performance degradation. If --file_log_level OFF does not change things, this may be a new problem. I am very concerned that it may be doing RAM monitoring. Joulescopes rely on fast RAM accesses for the Waveform widget performance. Sophos or any real-time malware detection software has the potential to significantly slow down RAM accesses, which is bad behavior regardless. However, it can dramatically affect the Joulescope UI.
Hopefully, your IT department can help confirm if this is an issue with Sophos. Post again to let me know how it goes!
just to let you know that this is indeed a Sophos issue.
My IT department temporarily disabled real-time files scanning, and it worked much better.
Unfortunately, they don’t want the scan permanently disabled.
They tried setting up exceptions (based on the software’s installation directory (“C:\Program Files\Joulescope”) and the “joulescope.exe” file), but it didn’t help.
Sophos doesn’t seem to allow disabling RAM scanning.
Do you have any other suggestions I could ask my IT department about?
Thanks.
yoann
Hi @Yoann - Thanks for following up and letting me know that Sophos causes the performance degradation.
Unfortunately, I don’t have any great recommendations other than don’t use antivirus software that kills computer performance. I am not familiar with Sophos, and I have no recommendations on configuring appropriate exceptions.
Will your IT department allow you to have a dedicated, stand-alone computer? Plenty of affordable options exist. Any of the newer Intel N150 processor-based small-form factor computers work fine. I have the Beelink Mini S13 with 16 GB RAM and 512 GB SSD, $339 on Amazon. For longer recordings, you can buy an external HDD. You can record two full weeks of full-rate data onto a 20 TB HDD, such as this one for $439. Smaller HDDs are even more affordable.
Hello Mike,
someone from the IT department has figured out how to restore normal operation. This means Joulescope.exe now launches quickly and, most importantly, there are no more regular pauses.
There is indeed an exclusion that needs to be implemented :
And the strategy is as follows:
So I won’t be getting a new PC and a 20TB HDD.
That’ll have to wait for another time.
Thank you.
Yoann
Great to hear, and thanks for posting the solution! This will help definitely help other Joulescope customers force to use Sophos!
