JS220 UTC time incorrect - FIXED
Joulescope UI 1.2.4 contains a fix for issue #296. Prior to this fix, the UTC time could jump back 35.7 minutes due to a improperly handled 32-bit sample ID counter rollover. We understand that this behavior could have been a severe problem for some measurements.
Prior to this fix, you could observe this issue in several ways:
  1. Events capture by a JS220 not correctly aligning to wall-clock time
  2. JLS file durations 35 minutes shorter than expected
  3. Waveform view not updating for about 35 minutes
  4. Waveform widget breaks and shows no data when using multiple Joulescopes
Despite the issue, the integrated quantities charge and energy were still correct.
Please use this topic to discuss any concerns related to measurements taken before this fix.
