Need to evaluate a 300 second duration on the x axis without scrolling
is there a way to see a 300 second window all together? i.e delta t = 300 seconds
No matter what I try, it caps out at 67 seconds. I need this to properly calculate the average current over a 5 minute window. This would be more accurate than calculating csv values for that 5 minute window. I have peaks that are smaller than the highest sampling rate, but those are captured in JS220 software.
Hi @vatsal.gada and welcome to the Joulescope forum!
You have lots of options here, but here is what I recommend:
  1. For data that you care about and want to keep, record to JLS. Press the Signal sample recording button on the left-hand sidebar. Press again to stop the recording. Select View → File and then File → Open. Explore the data and dual markers.
  2. If you want more of an instantaneous view, increase the memory buffer size, assuming your host computer has enough RAM. You can also right-click on the Waveform widget Δt at the top right to set an exact duration to display that is less than the size of the total RAM buffer.
I have tried to indicate all of these interactions in the image below:
