It would be most useful if JouleScope would remember the setup of the UI. I find I have to reset it to the way I want it each time I start up the application.
Right now I am using JS with only the current waveforms and control displayed. The current range is “2A” and the display axis is “manual”. The voltage display is hidden. If I restart the UI these selections are not persisted.
Sid
To expand upon this future feature:
Joulescope currently starts in multimeter mode. The software should allow the user to configure the starting view which can be one of:
- Multimeter
- Oscilloscope
- User-saved configurations (zero or more)
In addition, the View menu should also display and allow the user to select any user-saved configuration. The user-saved configuration should remember the active views and waveforms.
