Power-off Joulescope when UI closes
When the Joulescope is first attached to the computer the power to the system under test is off, the way it should be I believe. Power is turned on when the UI is started (assuming the JS is selected). When the UI is closed the Joulsescope leaves the system under test powered on, which is a little inconsistent. It would be consistent if closing the UI also turned off the power to the system under test. Maybe a user preference?
Sid
A user preference under the “Device” section sounds good. Added Device.on_close, and will be in the next release!
@mliberty, sounds good :smile:
