Hi guys, I’m starting to use Joulescope and I have some doubts.
I would like to measure the long-term consumption of a temperature Beacon. In my last test I used a fixed source of 3.3V. But this time I would like to perform the test using the beacon battery itself as a power supply.
Below I will list the step by step I did in mode 1 (Measurement of consumption of the beacon using a fixed source of 3.3V):
In the case above I divide the accumulator value of uAh by the number of hours of my test.
253,101/15 = 16.87uA (This I consider my real average consumption of the beacon)
How could I replicate the same test above using the Renata CR2477N battery? I made a schematic of how I think the assembly would be.
Is this right? Do I have to consider some point? I’m at a loss about this setup using the CR battery
