Representing a constant voltage signal in a .jls file
The JLS file format does not have a way to represent a constant signal. It just knows samples. You would just need to create a voltage signal with the same UTC entries and number of samples as the current signal. You could include the power signal only (no current, no voltage) if you want.
You now have the ability to enable the power plot and close the current and voltage plots from the JLS.
