Joulescope GUI comes up, but does not register input voltage (using screw-collar banana jacks; checked with meter +3.04V on jacks metal).
Is there any diagnostic check in GUI for hardware connection; i.e., self-test or readback serial number?
I may have gotten wrong (default “HP Printer”?) driver installed by plugging in USB before installing software.
Here’s log:
- Joulescope User Interface *
 - UI Version = 0.4.4 *
 - Driver Version = 0.4.4 *
info = {
“joulescope”: {
“ui_version”: “0.4.4”,
“driver_version”: “0.4.4”
“platform”: {
“name”: “win32”,
“python_version”: “3.7.3 (v3.7.3:ef4ec6ed12, Mar 25 2019, 22:22:05) [MSC v.1916 64 bit (AMD64)]”,
“executable”: “C:\Program Files (x86)\Joulescope\joulescope.exe”,
“frozen”: “C:\Program Files (x86)\Joulescope”,
“app_path”: “C:\Users\Pete\AppData\Local\joulescope”,
“log_path”: “C:\Users\Pete\AppData\Local\joulescope\log”
INFO:2019-07-01 09:36:39,356:logging_util.py:139:root:logging configuration: stream_level=30, file_level=20
INFO:2019-07-01 09:36:39,356:driver.py:1136:joulescope.driver:Find all Joulescope bootloaders and run the application
INFO:2019-07-01 09:36:39,357:main.py:1052:joulescope_ui.main:configure high DPI scaling
INFO:2019-07-01 09:36:39,358:main.py:1061:joulescope_ui.main:Start Qt
INFO:2019-07-01 09:36:45,112:main.py:665:joulescope_ui.main:_device_change add disable
INFO:2019-07-01 09:36:45,245:settings_widget.py:48:joulescope_ui.oscilloscope.settings_widget:on_signalsAvailable([‘current’], [‘current’])
INFO:2019-07-01 09:36:45,260:settings_widget.py:48:joulescope_ui.oscilloscope.settings_widget:on_signalsAvailable([‘current’, ‘voltage’], [‘current’, ‘voltage’])
INFO:2019-07-01 09:36:45,261:settings_widget.py:48:joulescope_ui.oscilloscope.settings_widget:on_signalsAvailable([‘current’, ‘voltage’, ‘power’], [‘current’, ‘voltage’])
INFO:2019-07-01 09:36:45,263:oscilloscope.py:338:joulescope_ui.oscilloscope.oscilloscope:on_scrollbarRegionChange(25.0, 30.0, 1)
INFO:2019-07-01 09:36:45,265:main.py:424:joulescope_ui.main:on_multimeterMenu(True)
INFO:2019-07-01 09:36:45,302:main.py:624:joulescope_ui.main:_developer_cfg_apply
INFO:2019-07-01 09:36:45,781:main.py:637:joulescope_ui.main:device_close None
INFO:2019-07-01 09:36:45,782:main.py:687:joulescope_ui.main:_device_scan
INFO:2019-07-01 09:36:45,782:driver.py:1127:joulescope.driver:scan_for_changes 0 devices: 0 added, 0 removed
INFO:2019-07-01 09:36:45,782:main.py:700:joulescope_ui.main:current device = disable, True
INFO:2019-07-01 09:36:45,783:win32_device_notify.py:80:joulescope.usb.winusb.win32_device_notify:open
INFO:2019-07-01 09:37:58,113:main.py:637:joulescope_ui.main:device_close disable
INFO:2019-07-01 09:38:00,637:main.py:942:joulescope_ui.main:Invalid filename, do not open
INFO:2019-07-01 09:38:04,259:main.py:415:joulescope_ui.main:Device notify
INFO:2019-07-01 09:38:04,260:main.py:687:joulescope_ui.main:_device_scan
INFO:2019-07-01 09:38:04,262:driver.py:1127:joulescope.driver:scan_for_changes 0 devices: 0 added, 0 removed
INFO:2019-07-01 09:38:04,263:main.py:700:joulescope_ui.main:current device = disable, True
INFO:2019-07-01 09:38:18,048:main.py:424:joulescope_ui.main:on_multimeterMenu(False)
INFO:2019-07-01 09:38:35,887:main.py:637:joulescope_ui.main:device_close disable
INFO:2019-07-01 09:38:35,962:win32_device_notify.py:86:joulescope.usb.winusb.win32_device_notify:close
