Timestamps in joulescope viewer vs. pyjls
Dear Joulescope-Team!
I have recorded various measurements, resulting in different jls-files. Somehow I noticed that the timestamps of the joulescope viewer and the timestamps resulting from the pyjls function sample_id_to_timestamp() do not fit…I wonder whether I did something wrong…
Here you can see my python script. It should simply measure how long the duration of the jls file is:
import sys
import numpy as np
import pyjls.binding as jls
def load_signal(reader, signal):
samples = reader.fsr(signal.signal_id, 0, signal.length)
ids = np.arange(signal.length)
ts_ns = reader.sample_id_to_timestamp(signal.signal_id, ids)
ts_s = ts_ns.astype(float) \* 1e-9  # seconds
return ts_s, samples
def find_signal(signals, candidates):
for s in signals:
    if s.name.lower() in \[c.lower() for c in candidates\]:
        return s
return None
def compute_duration(filepath):
reader = jls.Reader(filepath)
\# read list of signals (compatible with both v1 and v2 pyjls)
signals = list(reader.signals.values()) if hasattr(reader.signals, "values") else list(reader.signals)
if not signals:
    print(f"{filepath}: No signals found in file.")
    reader.close()
    return
\# try to pick "power" signal, otherwise fall back to first one
sig = find_signal(signals, \["power", "p"\])
if sig is None:
    sig = signals\[0\]
    print(f"Warning: no 'power' signal found, using '{sig.name}'")
if sig.length == 0:
    print(f"{filepath}: Signal '{sig.name}' contains no samples.")
    reader.close()
    return
\# load timestamps via the same function your main script uses
time_s, \_ = load_signal(reader, sig)
reader.close()
if len(time_s) == 0:
    print(f"{filepath}: Could not read timestamps.")
    return
\# compute duration
duration_s = time_s\[-1\] - time_s\[0\]
print(f"File:      {filepath}")
print(f"Signal:    {sig.name}")
print(f"Samples:   {sig.length}")
print(f"Duration:  {duration_s:.6f} seconds")
print(f"Duration:  {duration_s\*1000:.3f} ms")
if _name_ == “_main_”:
if len(sys.argv) < 2:
    print("Usage: python checkTimeCalculation.py <file.jls>")
    sys.exit(1)
compute_duration(sys.argv\[1\])
When I execute this code on one of my jls-files, the duration calculates to 476 seconds. If i open the same file in the joulescope viewer, it shows a duration of 443 seconds…Do you know what the problem could be? I am working with pyjls version 0.15.0
best Anna
Hi @anna - The script you posted does not properly use sample_id_to_timestamp. The returned timestamp is in our time64 format which uses int64_t. The actual increment is 2**-30 = 9.313225746154785e-10, not 1 ns as the code assumes. You also want to keep using the int64 format until you compute the duration. 64-bit double precision floating point numbers only have a 53-bit mantissa. Converting to double before taking the difference can cause precision loss.
I have updated the checkTimeCalculation.py script to fix both issues:
import sys
import numpy as np
from pyjls import time64
    t64 = reader.sample_id_to_timestamp(signal.signal_id, ids)
    return t64, samples
    for s in signals:
        if s.name.lower() in [c.lower() for c in candidates]:
            return s
    return None
    if not signals:
        reader.close()
        return
    sig = find_signal(signals, ["power", "p"])
    if sig is None:
        sig = signals[0]
    if sig.length == 0:
        reader.close()
        return
    t64, _ = load_signal(reader, sig)
    reader.close()
    if len(t64) < 2:
        return
    # compute duration
    duration_t64 = t64[-1] - t64[0]
    duration_s = duration_t64 / time64.SECOND
    print(f"Duration:  {duration_s * 1000:.3f} ms")
if __name__ == "__main__":
        sys.exit(1)
    compute_duration(sys.argv[1])
Does this now work for you?
It worked, thanks so much!! you are really offering great support here on this forum
:slightly_smiling_face:
