Hi @konlog and welcome to the Joulescope Forum! Sorry to hear that you are having issues with the latest UI version. Unfortunately, that image chopped off the error. However, I think that error indicates that the configuration that stores the Joulescope UI state between program invocations is invalid. You can fix this by deleting the existing configuration, which will revert to the defaults.
The process varies based upon your host operating system.
Windows
You need to delete the configuration file:
%LOCALAPPDATA%\joulescope\config\joulescope_ui_config.json
Method 1:
Open Windows file explorer
In the navigation bar, type: %LOCALAPPDATA%\joulescope\config
Select joulescope_ui_config.json
Press delete
Install Joulescope UI 1.0.23 and start the Joulescope UI
Method 2:
Open a command prompt
Type: del %LOCALAPPDATA%\joulescope\config\joulescope_ui_config.json
Close the command prompt
macOS
~/Library/Application\ Support/joulescope/config/joulescope_ui_config.json
Method 1:
Open Finder
Select Go → Library
Select Application Support, joulescope, config
Control-click on joulescope_ui_config.json
Select Move to Trash
Hi @konlog - I am going to assume that the above fix worked from you since you did not follow up. Starting with Joulescope UI 1.0.28 [download], the UI will be able to report errors like this with much more detail. If this happens again with 1.0.28 or newer, please submit the error.
