Hi JouleScope Forum,
I just got a JouleScope for energy measurement tasks. At the moment I’m using the JouleScope in a similar way as using an oscilloscope: start capture → wait for a certain amount of time → stop capture → read samples.
After conducting a few energy measurement tests, I notice that sometimes the JouleScope would give me varying amounts of nan in current and voltage readings. Can anyone help me with the following issues:
- nan in sample readings
 - find out what does “in frame_id mismatch xxx!= 0” mean
This is some information of an example test script and system info:
example test script:
import joulescope
from joulescope.v1.js220 import DeviceJs220
import numpy as np
from time import sleep
from numpy.typing import NDArray
OSC_FREQUENCY = 5000
TIME_WINDOW = 1200
for _i in range(20):
    print(f"Test iteration {_i + 1}")
    joulescope_device: DeviceJs220 = joulescope.scan_require_one(
        name="joulescope", config="auto"
    print(f"JouleScope {joulescope_device.model} is connected.")
    joulescope_device.open()
    # Set configuration
    joulescope_device.parameter_set("sampling_frequency", int(OSC_FREQUENCY))
    assert (
        int(joulescope_device.parameter_get("sampling_frequency", "actual"))
        == OSC_FREQUENCY
    joulescope_device.parameter_set("buffer_duration", int(TIME_WINDOW))
    assert (
        int(joulescope_device.parameter_get("buffer_duration", "actual")) == TIME_WINDOW
    joulescope_device.start(contiguous_duration=TIME_WINDOW)
    print("Started data streaming.")
    if not joulescope_device.is_streaming:
        print("JouleScope is not streaming after start!")
        break
    print("Waiting for 1190 seconds.")
    sleep(1190)
    joulescope_device.stop()
    print("Stop data streaming and get samples.")
        starting_sample_id,
        ending_sample_id,
    ) = joulescope_device.stream_buffer.sample_id_range
    samples = joulescope_device.stream_buffer.samples_get(
        starting_sample_id, ending_sample_id
    statistics = joulescope_device.stream_buffer.statistics_get(
    current: NDArray[np.float32] = samples["signals"]["current"]["value"]
    voltage: NDArray[np.float32] = samples["signals"]["voltage"]["value"]
    nan_current = np.sum(np.isnan(current))
    nan_voltage = np.sum(np.isnan(voltage))
    if nan_current > 0 or nan_voltage > 0:
        print(f"Got {nan_current} nan in current values.")
        print(f"Got {nan_voltage} nan in voltage values.")
        print("Fail to fetch complete waveform")
    joulescope_device.close()
    print("JouleScope is closed.")
snapshot of test result:
Test iteration 1
JouleScope js220 is connected.
Got 5598 nan in current values.
Got 5598 nan in voltage values.
Test iteration 2
in frame_id mismatch 983 != 0
Got 1025 nan in current values.
Got 1025 nan in voltage values.
Test iteration 3
in frame_id mismatch 17226 != 0
Got 873 nan in current values.
Got 873 nan in voltage values.
a.t.m I’m sticking with Python 3.8 so I chose to install joulescope version 1.1.6
python -m joulescope info
System information
Python: 3.8.10 (default, May 26 2023, 14:05:08)
[GCC 9.4.0]
Platform: Linux-5.15.0-75-generic-x86_64-with-glibc2.29 (linux)
Processor: x86_64
executable: /home/allan/.cache/pypoetry/virtualenvs/testing-S71WflWI-py3.8/bin/python
frozen: Falsejoulescope version: 1.1.6
Found 1 connected Joulescope:
JS220-000882 ctl=1.0.4 sensor=1.0.3
