View "notes" of signal recording
I made a series of signal recordings using the UI, including details of the test setup in the “Notes” section. How do I see those notes when I open the .jls in the UI?
I can see the ascii characters if I open the .jls in a text editor, so I know they are there.
(UI v1.0.23 with JS220)
Thank you
Hi @mraines and welcome to the Joulescope forum!
Unfortunately, the Joulescope UI does not yet have the ability to display the JLS file metadata. I just added issue #209 to capture this feature.
In the meantime, I think that you can inspect the JLS file from the command line using python. See the workaround on in the issue comment.
Ok thanks for the quick response! Glad I wasn’t missing something obvious
