Hey guys… ![]()
I am currently working on a project that involves monitoring the power consumption of low-power IoT devices, specifically a battery-operated sensor node. The current consumption fluctuates significantly, from a few microamps in sleep mode to several milliamps during active transmission.
I have been using my Joulescope to measure the current draw, but I’m noticing that the readings tend to vary quite a bit, especially during the transition from sleep to active states. I’ve tried adjusting the sampling rate and experimented with different settings in the Joulescope UI, but I’m still having trouble getting stable, accurate measurements. I’m particularly interested in capturing the spikes accurately without losing detail on the low-current states.
Here is the points that was I faced in my project:
Are there recommended settings for measuring devices with such a wide dynamic range of current? I’ve been using auto-ranging, but I wonder if manual adjustments might yield better accuracy.
I’ve noticed some noise in the readings that I suspect might be affecting accuracy. What are the best practices for minimizing noise in such low-current measurements? Could the noise be coming from the way my device is powered or from environmental factors?
Does anyone have tips for post-processing the data to better understand the power consumption profile over time? I’m currently exporting the data to CSV and using Excel, but I’m open to using other tools if they offer more robust analysis features.
I also check this: https://forum.joulescope.com/t/accurate-measurement-of-mcus-sleep-currentsalesforce But I have not found any solution. Could anyone guide me about this?
Thanks in advance!
Respected community member! ![]()
