Joulescope App UI to indicate signals that are not enabled
As a foolproofing thing:
It would be great if the Waveform widget (or any other widget that uses this) would indicate that a signal isn’t actually enabled in the Device Control.
As in: The waveform widget’s UI shows options for “enabling” the GPIO streams. However, if the IO are not enabled in the Device Control, it just shows a space on the graph where the IO signal should be, but it’s blank. It would be great to have a little warning or info-box stating that if I wanted to see that signal, I needed to turn it on in the Device Control panel (ideally with a copy of the Device Control icon as well)
Hi @sethk and thanks for the suggestion.
I agree that the signal selection is not as straightforward as we would like. The additional complication is that the UI supports an arbitrary number of connected Joulescopes. The Waveform widget supports up to 4. We need to figure out how to make this work intuitively in all cases. I am on vacation this week, and I will reply again when I return.
